I have a 99 F-150 which has been a fantastic truck. I have several minor problems that someone may know how to fix.
1. My wipers come on sometimes when they are in the off position.
2. The odometer does not show up at all, until several minutes after starting the vehicle.
3. My passenger side door lock does not work. Actuator?
1. Usually the multifunction switch
2. Fairly common problem with 99 model year.. usually have to replace the cluster to fix.
3. Likely the actuator, yes.
