E4od Help
Old Jun 18, 2004 | 12:12 PM
MOOSEKNUCKLE85's Avatar
MOOSEKNUCKLE85
Talking E4od Help
Hello All. I Have A 92 E350. Cab And Chasis- The Ambulance Special
I Just Purchased It.the Trans In It Is Reman, Put In 40k Ago. The Trans Started To Act Up/ Always Shifts Hard Into 2nd-started To Stay In Second For A Long Time Then Shift. Now When Hot It Stayes In 2nd
Wont Go Into Third, If It Does It Droppes Right Back Out With Any Acceleration. Also Will Lose Reverse When Hot! I Will Be Rebuilding This Myself- So Any Heads Up Will Help( What Kind Of Conv-updated Parts-flashing Of The Controller-or Even Any Pre-diagn. Of The Elect. Componants! Thank
P.s.
The Trucks Only Purpose Will Be Hauling 2 4,000 Lb Truck
On A 30ft Gooseneck, Once Or Twice A Month!
Old Jun 18, 2004 | 02:05 PM
f250freak's Avatar
f250freak
I've got a 92 F250 with the E4OD. Since you're tranny just has 40k on it, you might try a simple fix before trying a total rebuild. The aluminum valve bodies are notorious for sticking. Especially since aluminum exands quite a bit when hot, it sounds like yours might be sticking. Replace the aluminum valve body with a heavy duty steel one. This is a simple procedure, and even if it doesn't fix it, you can always use this new, heavy duty, steel one in your rebuild. It will help the shifts and be much more robust.
Old Jun 18, 2004 | 02:21 PM
MOOSEKNUCKLE85
Thanks For The Info!
Any One In Particular I Should Ask For?or Is It A Direct Replacement?
Wheere/ How Much If You Had To Guess?
Old Jun 23, 2004 | 12:35 PM
MOOSEKNUCKLE85
P.s.
DO YOU GUYS THINK A SOFT REBUILD= UPGRDED CONV, FACTORY
O-HAUL PACKAGE= PLATES, FRICTION,
SEALS, GASKETS, WILL SOLVE THIS PROBLEM! ANY ADVISE WILL HELP
IM PRETTY SURE YOU GUYS ARE 10 FOLD AS EXPERIENCED IN THIS AS I AM!
SO ANY DIAG ADVISE WILL HELP ME GO ABOUT THIS THE RIGHT WAY.
THANKS!
Old Jun 29, 2004 | 01:26 PM
f250freak's Avatar
f250freak
It has been a while since I got mine quoted. It seems like the new valve body was around $100 and the labor was about the same. Talk to a transmission guy. Mine acted like it was something that he had done quite a few times. As far as the difficulty. If I am remembering right, the valve body is located right underneath the tranny pan. You pull the pan (after draining the fluid) and it is right there. All you have to do is remove a couple of bolts, pull it off, and bolt the other back on.
I really like my new valve body. The shifts are more positive, and it should last longer, be more robust, and doesn't stick.
