missing
Old Jun 18, 2004 | 09:29 AM
nomamen915's Avatar
nomamen915
Angry missing
I have e-150 conversion van 2000 4.6 v8 one of my hoses busted and was spraying water on plug #5, corrected hose and replaced plug, then ran ok for about 300 miles then started missing or idleling rough, and getting worse, the check engine soon light came on but goes out. What else can i try.
Old Jun 18, 2004 | 06:06 PM
pfogle's Avatar
pfogle
sounds like you probably shorted out the c.o.p.
Old Jun 19, 2004 | 05:52 AM
Adventure's Avatar
Adventure
I didn't think that the V8 used coil on plug. I thought that only the V10 did. Did you measure the wiring resistance?
Old Jun 21, 2004 | 08:39 AM
nomamen915's Avatar
nomamen915
Missing
I ended up replacing the coil and that appeared to be the problem, thanks.
I susspected the coil, but I figured since it was an electronic part either it worked or it didn't
rcraft
Mar 30, 2014 03:55 PM
gumper 123
Feb 22, 2011 08:47 PM
tess100
Mar 11, 2004 12:10 AM
adjustrite
Modular V8 (4.6L, 5.4L)
Oct 17, 2003 02:56 PM
mvtofino
Sep 6, 2003 01:09 AM
