Thank you .
This is what I have fixed with all of your help since buying the truck in April.
Popping when turning and slow manuvers.......Unbolted tranny crossmember bolts and packed it full of grease.Loose steering....adjusted steering box gear mesh.I had a vibration at 25- 35 mph.....after 1 1/2 month and 2 trips to the drive shaft shop ,the drive shaft was out of balance.Water pump went out...10 hour job... rattling or buzzing from tranny pan....turned out to be a stuck valve in the valve body.This was the only problem I could not find any threads on .Poor idle and bad gas milage........Found out how to pull codes http://fordfuelinjection.com/index.htm ,,,Egr problem.I cleaned the MAF,IAC and the EGR and throttle body and replaced a small vacum line.Runs great.
Thanks again for taking the time to help,
