Turn signal problem help!
Old Jun 17, 2004 | 05:30 PM
Eric224's Avatar
Eric224
I instaled a new stereo in my 89 4cyl ranger. Stereo is fine turn signals dont work any more. Flashers work fine . Checked all the fuses and replaced the flasher fuse im completely stuck jelp.
Old Jun 17, 2004 | 07:30 PM
Thoth88's Avatar
Thoth88
Is it possible that when you installed the radio you unplugged a harness inside the dash? Maybe bumped a conector enough the break the connection?
Old Jun 18, 2004 | 03:19 AM
87 XLT's Avatar
87 XLT
The only differece between turn signals & flahers are a different fuse & different flasher. Are your backup lights working. If not, check the turn signal fuse. On my 87 turn & backup lights are on the same fuse, probably the same on yours.
