Cluster lighting problems
Old Jun 17, 2004 | 02:24 PM
ZUMMAK1's Avatar
ZUMMAK1
Question Cluster lighting problems
Well i go from one problem to another. first the far right display light is not working. but the rest are. and the steering colume display light is also no working. Any idea's.
Old Jun 17, 2004 | 03:24 PM
Mil1ion's Avatar
Mil1ion
What year of truck ?
Some of the cluster lighting bulbs can be changed without removing the cluster.
The one on the right side of the cluster is one of them.
You can pull the bulb holder for the gear selector out the bottom from the steering column cowl.
The bulb for the cluster is a #194
The bulb for the gear selector is a round bayonet bulb #161
If you want to remove the cluster completely you will find the directions in a thread in this forum *dash lights*.
Old Jun 18, 2004 | 09:04 AM
ZUMMAK1's Avatar
ZUMMAK1
sorry
It's a 78 ford f-100
Old Oct 7, 2004 | 11:14 AM
cddyal's Avatar
cddyal
Zummaki, I have a 1978 Ford F-100. Sounds like I'm experiencing some of the same things you are. Lemme know what interesting things you find out.
Old Oct 7, 2004 | 11:29 AM
73Custom's Avatar
73Custom
Do you mean the right of the guage cluster is dark? Or do you mean the heater control lights don't work? There is a bulb in the back of the heater control, and 2 bulbs in the back of the instrument cluster. Check bulbs and make sure the contacts are clean.
When I removed the blinker switch from my '78 parts truck, I noticed that the steering wheel must be removed to replace the gear selector bulb. Removing the wheel is easy, but you need a special steering wheel puller, which can be bought or rented from a parts store.
Marty
Old Oct 28, 2004 | 02:34 PM
Redbob's Avatar
Redbob
I'd like to revive this thread, since I've got this same problem, in a '78 (fullsize of course) Bronco:
None of my gauge cluster lights work reliably; having pulled the cluster, I can see that the problem is that the plastic is well on its way to biodegrading, and the socket no longer keeps the bulb in contact with that little printed circuit business.
Does anyone have a source for a new gauge cluster? Or has anyopne come up with a good fix for this?
Should I simply run individualwires to the individual bulbs?
All ideas welcomed, and only the truly silly ones will be openly laughed at!
Thanks,
- R
Old Oct 28, 2004 | 03:17 PM
73Custom's Avatar
73Custom
That's a common problem, the white plastic back panel gets brittle and falls apart. Get a 'new' back panel from a 73-79 pickup/Bronco or '80s Econoline van with the same guage arangement as your pickup. Just swap the back panel, using your original guages and flex circuit.
Marty
Old Oct 28, 2004 | 03:21 PM
Redbob's Avatar
Redbob
Early '80's Econolines used the same instrument cluster?
Nobody still has these "NOS" do they?
Thanks,
- R
Old Oct 28, 2004 | 04:13 PM
firstonraceday's Avatar
firstonraceday
As a matter of fact, I just noticed recently that one of the site sponsors, Jeff's Bronco Graveyard, has the back plates listed now. I going to be getting one myself, to rebuild the original gauge cluster for my '77.
Old Oct 28, 2004 | 04:16 PM
Redbob's Avatar
Redbob
Jason:
Thanks a bunch; last time I checked Jeff's - and I've been there a bunch! - they didn't have them.
Thanks again,
- R
Old Oct 29, 2004 | 12:10 AM
biz4two's Avatar
biz4two
Talking
Ya...Thanks a bunch! I surf Jeff's all the time, but never came across them. Heck...I'm buying two...one never know's when they will stop being available.
Old Oct 29, 2004 | 12:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
As far as I can figure out it may have been some kind of problem with a few of those backs. I have seen trucks of many years with good backs but then a few show up with bad ones. It may be a lot number or a plastic material problem...
I would not buy two of them tho. The one you buy will probably outlast the truck. If it did fail you probably would not be able to find the other one or it would have been broken or cleared out in some junk throwing party...
Old Oct 29, 2004 | 02:20 AM
f250rangerexplorer's Avatar
f250rangerexplorer
none of my lights work except the slector light on the column. they all work when i turn the high beams on. i posted this a long time ago and didn't get much response. i haven't checked the lights but they wouldn't work at all if they were blown. why does this work with the highs but not the lows? i'm lost here and in need of help bad. i ran out of gas one night because of this dang light problem. help would be appriciated a lot.
Drive It Like You Stole It!!!
Old Oct 29, 2004 | 11:07 AM
Mil1ion's Avatar
Mil1ion
Clarification to things mentioned here.
There are not 2 bulbs on the back of a cluster, there are at least 7 ,plus the T/S bulbs.
The gear selector bulb can be reached from behind the cowl on the steering column, making the removal of the steering wheel UN-necessary.
There are some of us on FTE that have used cluster backs please check the classifieds.
I have noticed that more of the cluster backs that breakdown are in HOT climate states. Arizona,Texas,Florida,etc
It is quite rare for a Canadian Truck cluster back to breakdown.
Old Oct 29, 2004 | 02:25 PM
TxBrokenarrow's Avatar
TxBrokenarrow
I Had The Same Problem With Mine.78 Bronco.check Fuse 1st.i Went To Junk Yard And Pulled One Out In Better Condition Out Of A 78 Van...not Real Hard To Do...printed Circuit Boards Can Be Had From Lmctruck.com...good Luck
