Test Pipe?
Old Jun 17, 2004 | 10:52 AM
Spktyr's Avatar
Spktyr
Test Pipe?
I want to get a test pipe for my 86 F150 4x4 302/AOD to see if the cats are really causing my power loss problems. Does anyone know where I can get one?
Old Jun 17, 2004 | 03:18 PM
lmadore's Avatar
lmadore
The problem is, I don't think that they can be sold to just anybody.
Old Jun 17, 2004 | 04:49 PM
fai4g63's Avatar
fai4g63
Since your converters are built into your Y pipe, you would need an exhaust shop to fab up some custom pipes to bypass your converter. If you want to check your converters backpressure you can purchase a pressure gauge that threads into your o2 sensor bung.
Old Jun 21, 2004 | 04:00 PM
mb43's Avatar
mb43
I got an old cat at a junkyard and hollowed it out. Funny thing, I forgot to put the real cat back on and the truck passed Massachusetts emissions with flying colors..
YMMV
mb
Old Jun 22, 2004 | 10:39 AM
lmadore's Avatar
lmadore
Cleaned out cats can cause excessive backpressure. Loss of torque.
Old Jun 22, 2004 | 11:31 PM
fai4g63's Avatar
fai4g63
How can removing a restriction in the exhaust such as a converter, cause more backpressure. As long as you are running a muffler your torque should not be affected in a bad way. Your power and fuel mileage should increase.
