Predator turbo lag
I waited to jump on it for a few days because of the five cold start transmittion learning period, but should I have done that?
When it had the stock program, the turbo lag did not exist. Is this a common thing, or is there something that I need to do?
Thanks
Mine in 'stock' tune has some lag as well.. Bout, the same with the 65 tune 'ONLY' when it hooks up Yee Haa!! Like a speeding locomotive.. If merging into traffic, I hold the brakes 'just' a bit before launch.. Either tune..
Do you have adjustable pedals? You might have your tech check the accelerator pedal. If it is not putting out the right output, could cause problem.
Don't have the adj. pedals, so no chance there.
sorta like the chicken or the egg -
you gotta have something before the other can be...
but in OUR trucks case, there is a correct answer...
you gotta have boost before real power,
but you have to have exhaust going thru the turbo before it can make boost !
so our boost must come before REAL power…
our trucks build the REAL power this way:
(apologies if this is too much of a primer for those in the know)
(or if I have NO clue what I'm talking about here
)1) the normally aspirated engine is fired....
2) after it burns the fuel to get going, it send the exhaust out thru the turbo
3) the turbo has an impeller in the exhaust flow that is connected to an impeller in the intake flow... (somewhat like a gearbox in that it has two sizes)
4) as the exhaust force builds, it spins the impeller which in turn spins the connected impeller in the intake side
5) the intake air is then compressed and FORCED into the intakes at a MUCH higher rate which gives much more air to allow firing the fuel at much more efficient rate... MORE POWER !
Bottom line...
you have to build boost to get the exceptional power ANY turbo charged engine can generate ~~~
no boost – very little power…
Even a jet plane has a pause when it starts off !!! but then hold on…
Try this in a safe place....
in an auto... hold the brake with your left foot...
increase the throttle to about 1000 to 1500 rpms for just a count and HOLD on as you drop the brake and floor the throttle at the same time...
That's called "NO TURBO LAG !"
I guess that I let the turbo wind up too much because before I knew it, I thought that some fog was rolling in!!! (even though it is almost 100 today).
Boy, the truck just lights up the tires if you let the turbo kick in too much.
What a blast
Now I wish I didn't know because my tires are going to need to be replaced!
it hurts to have your toes stepped on after they are already sore !!!
But don't know how it's physically possbile to build turbo boost until you build exhaust flow --- but what do I know ....
I just make my living with logic - not with "dizzles"
but I promise you the last four planes I rode on had turbo lag !!!
They slam the throttles,
you hear the turbos start to whine and
THEN you start to move.... just like in our trucks !
Maybe I should be in a Mercedes plane - then I'd unnestan :-)
What a blast
Don't do it too many times...
but now you know where the OH NO
point is if you need it...If u hold the brakes too long in my Ex it STILL breaks away and will start squirming sideways !!!!
I blame it on TrucksTV - when he installed the Banks system for about 8 gazillion dollars... and did that WILD burnout....
I could hear the turbo whining up and he wasn't moving so figured it was a brake stand and tried it
but did you notice any turbo lag THAT time
Heck no !!! YOU were grabbing the OH NO handle
It's like "This heavy thing isn't SUPPOSED to be able to do that" ?!?!?!
