Old Hustler won't start
Old Jun 16, 2004 | 07:15 PM
Hi Ho's Avatar
Hi Ho
I have an old, old Excel Hustler commercial mower. 2 cylinders and hydraulic drive. I use it to mow my "field" which is more like a large sloped lawn. I have a problem, however. The other day I went out to start it up and would not fire. That's where I'm still at today. It will not even try to start. It has spark to both spark plugs, it has fuel, it has air, it's not flooded. I have even tried spraying starter fluid directly in the cylinder and it still hasn't fired once. Does anyone here have any ideas as to why this thing won't even fire? The grass is two feet high now.
Old Jun 16, 2004 | 09:38 PM
Torque1st's Avatar
Torque1st
Posting Legend
Have the valves stuck?
Old Jun 16, 2004 | 09:43 PM
Hi Ho's Avatar
Hi Ho
I don't believe they have. I forgot to mention that I have check for compression many times and there is compression. Here is a picture of the mower and the engine in case it has any relavence.
Old Jun 16, 2004 | 10:53 PM
FTE Herman's Avatar
FTE Herman
If its fired off the flywheel its possible the the woodrift (sp?) key might have split and your 'timing' is off. See of the spark coincides with compression. Other that that I would have taken Eric's guess.
Old Jun 16, 2004 | 11:04 PM
eehoepp's Avatar
eehoepp
Is the fuel fresh?
I bought a used snowblower cheap a couple of winters ago because it wouldn't run. It started if you dribbled gas into the spark plug hole, but quit once the gas was burned.
There was 1/4" of ice in the float bowl. Dumped it out, filled it with fresh gas & it runs like a champ.
Good luck.
Cheers,
Eric
earnhardtracer38
Jul 30, 2022 04:38 PM
35l911
16
Apr 28, 2007 08:40 PM
bradmur
Nov 30, 2005 09:00 AM
Seifferlein
13
Nov 6, 2005 09:09 PM
