Need help with EGTs
Question is what would the next mod be to help lower EGTs? Would a AFE intake help any? Do I need a larger intercooler? Do I need to install a turboback intsead of the cat-back? Are there other modules/tuners that run cooler than others?
Any help would be appreciated.
Mark
I have the probe in the exhaust manifold. I can get 1200 flooring it up a freeway onramp and by the time 75-80 hits I am at 1200 (stock setting).
Check out my gallery, it has an open intake in it.
Are you saying that having my probe in the exhaust manifold is causing my reading to be too high? If I see 1200 at the manifold what do you think the temp is right before the turbo?
Sorry I though it was in the down pipe
.. Probe pre turbo in ex/manifold.. Elevation isn't much here though, 500 ft. or so, but the temp has been in the high 80'-low 90's here when tested..
The only way to tell is to switch gauges and probes.
What brand of gauge are you using?? Here's some posts of 'other' owners, with Isspro gauges with mis-readings.. I had 'previously' purchased an Auto Meter EGT, (not to slam any product) and noticed before the install that if 'bumped' slightly the needle would vary by 50-100 degree's.. Not the accuraccy I'm looking for.. Probably just a bad gauge.. Can happen.. Now I'm running the Isspro!! But seems to be reading OK....http://www.turbodieselregister.com/f...pic/31798.html
I can't believe you linked us to a Dodge site. Just kidding
I have looked here also and found some good diesel info. I am still deciding what guages to buy for my truck and have wondered about the accuracy of the different brands. Could you use a infrared thermometer (Raytek Portable Infrared Thermometers ) to measure the temp of the probe location to compare it to the guage reading? If mounted in the manifold, I guess the probe could be seeing higher exhaust temps than the outside of the manifold itself, but it might be accurate at an idle.I have been looking at these thermometers for other uses on my vehicle also. I thought of checking the trailer brake drum, trailer hub, and tire temps for problems that could be indicated by irregular temperatures. Most importantly, you could check injector condition my measuring the temps of each individual cylinder head location, looking for a weak (cooler) cylinder. It could also be used to check coolant thermostat opening temps. Not to mention the fun uses around the house, like frying pan temp or heat loss through windows and walls. The inexpensive models good to 525°F are less than $100, but the higher temp models (up to 1400°F) are about $300-$500.
The delta would be enough....it could not be comparable
Possible..
Sounds as if 'some' of the gauges/amplifiers aren't calibrated correctly.. But a 'manual' check would confirm your concerns.. The leadwire was not altered at all, and is Isspro as well as the thermo.. correct?.. Hard to believe you'd see those kinds of temps, with a cat back, in stock tune.. As a first step.. I'd give Isspro a call, 'or' the vendor where you purchased them and see what they recommend.. Maybe they'll send you another unit, or have more insite..
Sorry about the Dodge Link..Kinda like 'weeing' on Superman's cape.. Could be worse though, could'a been to the Asian Diesel guys!!
Thanks for the help.
