New member needs help
Old Jun 15, 2004 | 02:46 AM
Monster Duty's Avatar
Monster Duty
I've been looking around here for a few weeks and found so much GREAT info here .
This is my first diesel and don't have a clue , so I need all the help that I can get .
04 F350 CC LB SRW 4X4
I just did my first oil change yesterday @ 3200 miles , used a Motorcraft filter and Delo 15-40 . The truck sat for about an hour before I drove it . I started the truck , let it idle for about 5 seconds and put it into drive , pressed on the pedal just enough to get it to move and the truck started to buck/surge/bounce .after the rpms came up alittle it was ok and it didn't do it again until I shut it off and restarted it 30 minutes later and it did it in reverse .
CAN ANYONE HELP ?
TIA...monter duty
Old Jun 15, 2004 | 05:29 AM
SBV45's Avatar
SBV45
You'r not the first one to experience this. How many quarts of oil did you fill the crancase with? Did you loosen the oil fill tube cover and the oil filter cap (but not remove) before you took out the drain plug on the pan? When you checked your oil at the end of the change, where was the oil level.
Monster, do a search on this forum for first oil change and get yourself a beer and snack and read. Lot's of good stuff.
For the next newbie who is about to change their oil please measure what drains out! I have read 13.5 quarts. That is what I put in to get the oil on the dipstick at midway or top of the crosshatch on the dipstick.
Old Jun 15, 2004 | 09:45 AM
docgreen's Avatar
docgreen
Monster, I know what you are talking about. My new 03 excursion does the same thing. But I haven't changed the oil it has less than 400 miles on it. It seems to do it exactly after being ran to temp, left to cool down about half then fired up put in rev or drive and it bucks or jerks until you give it a hard throttle push.
SBV45, what makes these motors so picky on oil type and or level?
Old Jun 15, 2004 | 11:09 AM
Hjudge49's Avatar
Hjudge49
If you search the threads you will find the info that the fuel injection system works partially off the oil pressure system. If the oil foams, it doesn't properly pressurize the high pressure fuel rail.(or things to that effect). That is one of the reasons the proper oil needs to be used. Unless I'm having a sneior moment, I also recall that there is no windage tray in the oil pan and that significantly contributes to foaming if there is an overfull condition. The other thing you need to remember is that it takes as long as 20 minutes for all the oil to drain to the pan. If you run the engine to warm the oil, drain it and refill to the "full" mark, there's more oil in that engine than you think. Let it sit for an hour, and the pan is overfull. SBV45 is spot on. Mine takes right at 14 quarts to fill after a drain and filter change.
Old Jun 15, 2004 | 12:22 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Monster Duty…..HI,...and WELCOME to FTE, the only family Ford site dedicated to folks like us.
Truck guys and gals.
When you are ready to buy accessories select from the many sponsors at the top of each page, the will appreciate it.
Please take a moment to read the Guidelines then check this out.
https://www.ford-trucks.com/forums/s...d.php?t=247669
Old Jun 16, 2004 | 12:02 PM
Monster Duty
Talking
THANKS FOR ALL THE HELP !!!
It seems to have gone away . Just did it those two times .
I also checked the level of the oil and it was overfilled . Those Fumoto valves are AWESOME !
Thanks Again .
Monster Duty
Old Jun 16, 2004 | 12:41 PM
SBV45's Avatar
SBV45
Monster Duty, we are glad to be of help. We all changed our oil for the first time at one time or another. Enjouy the truck. Stick around FTE. I learn all kinkds of neat stuff. Good exhange of info.
