Aerostar Ford Aerostar
carpet pattern
Old Jun 14, 2004 | 09:11 PM
jvt71's Avatar
jvt71
Question carpet pattern
I have a 97 3.0, rwd, xlt and I was wondering if anyone out there might have the carpet patterns & dimensions so I could replace it cheaper than with an oem $$$ replacement carpet set.
Old Jun 15, 2004 | 09:01 AM
rickm5's Avatar
rickm5
i have a 91 ext, xl. i'm replacing my carpet myself. i bought a 6x9 area rug for the back. and another 6x9 one to cut up for the front. i used my old carpet for a template. the back 4x9 fit perfect from lift gate to rear of front buckets. the front will be a smaller area. still under construction. i snapped off a couple of the front seat bolts. now i gotta wrestle them out. a word to the wise. soak your seat attachments with alot of liquid wrench or pbblaster before you try to remove them, or you'll be in my shoes. ##!!! i found them sticking out underneath the van, on the floor pan, so i soaked them from the bottom too(now). i will have to tease out the other stubs with a "easy-out" or just drill through them and replace with new nut and bolt. also the seat belt bolts are a torx fitting. i highly recommend buyinga torx socket for your ratchet. they also are very stubborn, but mine is a 91 so its been down the road a little further. i also discovered a large rust hole on the passenger side front that i need to patch. hope you have better luck. this job is getting bigger instead of smaller at the moment. rick 91 aerostar xl.ext 199 tho miles and going......
dolphinride
Jan 24, 2015 06:05 AM
67and71_Carl
Dec 7, 2010 02:27 AM
TheDesertRat
Feb 21, 2010 06:12 PM
fatherdoug
General Automotive Discussion
Jan 29, 2007 01:58 PM
old_man_van264
Aerostar
Jul 7, 2003 03:58 PM
