I need your help please!!
Old Dec 30, 2002 | 01:15 PM
Brenner's Avatar
Brenner
First off, I have a 2001 Sport Trac with 44k on it.
Today while driving into work I noticed the "engine light" was on and the truck started riding rough, like it was missing. I called the dealership and took it in. I just got off the phone with them and was told that somehow the timing skipped a tooth which is causing it to mis-fire. This mis-fire bent a valve and the only way to fix it is to replace the engine! I can't speak civillyis up with that!?
Has ANY one heard of this happening before or something simular? I need to gather as much information as possible so I can call Ford and have them take care of this for me, this is just insane.
Thank you in advance for help.
Scott
Old Dec 30, 2002 | 01:58 PM
Lucykat1's Avatar
Lucykat1
Scott:
I had a similiar experience with my 1999 Ford Explorer but it was a spark plug that was creating the problem. Apparently it was arcing and causing the vehicle to jump or lurch forward like it was going to stall out.
Old Dec 30, 2002 | 02:04 PM
1956MarkII's Avatar
1956MarkII
Scott, get me your VIN and let me do some research on this. You said the truck was running poorly, but you didn't mention noise. If you had a bent valve (which I doubt), you would HEAR it. If it ain't knocking, I really doubt you have a bent valve.
Old Dec 30, 2002 | 02:07 PM
Brenner's Avatar
Brenner
>have a bent valve.
Sorry, i left that out I could hear it. sounded like crap. I don't have the VIN handy but I can try to get it and I'll get it to you.
Old Dec 30, 2002 | 03:44 PM
Jharger's Avatar
Jharger
I believe this is the SOHC engine, right? There were a couple TSB articles and recalls around the tensioner on the timining belt. When too much play gets into the belt, the timing cams can slip and then you can smack a valve with the piston. I hope you got the extended warranty. Either way, the entire engine does not have to be replaced as long as the bottem end is not damaged. Good luck.
1956MarkII's Avatar
1956MarkII
I checked and there are no TSB's (Technical Service Bulletins) on your vehicle. Again, a bent valve, THOUGH POSSIBLE,is pretty unlikely. You know your dealer- I don't. If they've always been upfront with you before, then they probably are now. Still, I can't ever recall a slipped belt causing a bent valve, which in turn would mean a whole new engine. Do yourself a favor: go to www.FlatRateTech.com and post your question in the appropriate forum. That site is manned by some of the best Ford tech's in the business. (They're independent of Ford.) Tell them EVERYTHING that has happened and the dealer's diagnosis. They'll give you their best advice. Definitely worth the time before you drop a few thou, right?
Old Dec 30, 2002 | 03:53 PM
Brenner's Avatar
Brenner
Thanks all. I'll check out that link and see what happens.
Old Jan 2, 2003 | 04:34 PM
ThePheonixx2's Avatar
ThePheonixx2
well it seems you have a newer explorer with less than 60,000 on it should'nt this be under somekind of a warranty? if so who cares you get a new engine at 44k (wish i could get a new engine)
-Eric
94 EB 140k still smokes the tires!
Old Jan 2, 2003 | 04:58 PM
Opera House Works's Avatar
Opera House Works
capesteve
21
Feb 10, 2017 07:08 AM
85F350IDI
Jan 12, 2017 12:56 AM
96_F250_Deezal
2004 - 2008 F150
Aug 26, 2014 08:14 PM
ApachePete
2004 - 2008 F150
Nov 7, 2011 10:59 AM
nmercier853
6.4L Power Stroke Diesel
Jun 28, 2011 10:06 PM
