Started the engine for the first time......Oops!
Old Jun 14, 2004 | 08:40 PM
nickmyron's Avatar
nickmyron
Unhappy Started the engine for the first time......Oops!
I just replaced the heads in my 86 Bronco (has a 351W). Because of a cracked valve the #1 cylinder was holding ZERO compression. So I replaced the heads (stock heads with new valve job). I also put a new Edelbrock 650 Carb.
I have been doing this for the past month (i work kinda slow) but today I finnaly fired her up!.....But I messed up.
I forgot to check what position the linkage was in! The throttle was wide open!
Not knowing this I fired it up, and BOOM it fired but it was ideling WAY too high!! at about 4500-5000 rpm! hmmmm I wonder why . In a panic I shut it off, (it was running for at a max of 4 seconds probably)
Anyway, I looked at the linkage and found the problem, I just need to adjust the bracket a bit and it should be fine. I took off the linkage and fired it up w/o the throttle and it sounded alright (much better then before) but the carb still needs to be tuned & adjusted, but thats normal. There was a little ticking sound that we think was a lifter because it had been sitting a while and the oil may need to circulate a bit more (I didnt run it very long). There was oil pressure so thats good.
Anyway, do you think I could have ruined anything by running it that high RPM right at the start?
Thanks,
Nick~
Old Jun 15, 2004 | 09:01 AM
beartracks's Avatar
beartracks
I'd say your chances are good you didn't hurt it. Not a good thing to do but you'll just have to see if it works out OK.
Old Jun 15, 2004 | 06:29 PM
f100guy's Avatar
f100guy
definately not good to do that because oil may not have been circulating enough yet before the high rpm cam along but just once won't hurt. i know idiotic people who rev it to the same rpms for about 5 or 6 seconds right after startup just to hear the mufflers. i guess that is why that el camino and monte carlo both bit the dust shortly after.
