replacement Hubs
Old Jun 14, 2004 | 07:57 PM
oclodge's Avatar
oclodge
replacement Hubs
My auto hubs on my 95 F150 ½ ton are making a lot of loud banging sounds so I got a set of milemarker manual hubs to replace them. My question is do I need to replace the wheel bering lock nuts or will the #302 hubs fit without them?
Old Jun 14, 2004 | 11:46 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
I Have A Similar Prob W/my 93' F-250. The Auto Hubs Make A Grinding/banging Sound When I Drive In 2h. I Thougt It Was The Hubs But Not So Sure Now. The Idea Was Introduced That The T-case Was Supplying A Limited Amount Of Power To The Front Drive And In Turn Causing The Problem. Unknown..hoping For The Best And It's Just A Hub Swap. Got Warn Premiums On The Way.
Old Jun 15, 2004 | 12:48 AM
Txquadhunter24's Avatar
Txquadhunter24
If you've got 5(if memory is right) bolts holding your auto huds on you just need to swap hubs nothing else.
But if you have like 3 bolts under the cover you'll need the man. hub conversionkit.
