ebrake front cable
Old Jun 14, 2004 | 11:44 AM
jwrboss302's Avatar
jwrboss302
ebrake front cable
I have a 76 F350 that needs a new front brake cable. I have replaced both back ones, but the front is frozen also. Is this the same cable as the F150/F250 2 or 4 wheel drive? or are they all different? Any help would be appreciated as to common applications or where to get one. Thanks
JWR
76 F350 360
78 F250 4x4 400 T-18
Old Jun 14, 2004 | 01:30 PM
don_79f250's Avatar
don_79f250
I just put a new front e-brake cable in my 79 f250. Here's the tiny bit of insight I can offer: When shopping for it, I had to know wheel base, regular or double cab, etc. 'cause that directly affects the length of cable you need. There are several different lengths available.
If your parts store can't tell for sure, maybe you could pull the old one - since you're replacing it anyway - measure it and check the length of available ones.
