ABS light
Old Jun 13, 2004 | 05:54 PM
clarkmrs's Avatar
clarkmrs
ABS light
ABS light is on. Book says brakes will work ok. Safe to drive?
Old Jun 13, 2004 | 07:01 PM
dogman's Avatar
dogman
Yes, But you need to get it checked.
Old Jun 13, 2004 | 07:03 PM
maa139's Avatar
maa139
Could be that the fluid level is just low. Or, if you've had to jump on the brakes recently, the proportioning valve could be stuck out of center. Bleeding the brakes usually fixes that.
Old Jul 10, 2004 | 07:43 PM
geneG's Avatar
geneG
On my 02 have had the sensor replaced in rearend. This does the trick.
mine was under warranty
