Unidentifiable Part
Old Jun 13, 2004 | 05:32 PM
miked79928's Avatar
miked79928
Unidentifiable Part
Hey guys I need your help here. I was under the hood of my 89 F150 4.9l and noticed a white vacuum line that went from a taped bundle to what appears to be a switch in the back corner of the engine compartment on the passenger side. The line was deteriorated so I replaced it, but my question is what is this "switch" and what does it do? I have always lost my vent setting on the a/c when going up a hill or something similar; could this have been the cause? I can find no mention of this part in the Chilton manual. Thanks.
Old Jun 13, 2004 | 05:46 PM
andym's Avatar
andym
There's a vaccuum line going from the vaccuum tree on the intake manifold to the MAPS sensor in about the same location you describe. If you unplug it, and the truck dies immediately, that's probably what it is.
Old Jun 13, 2004 | 06:03 PM
miked79928's Avatar
miked79928
Cool thanks for clearing that up.
Old Jun 13, 2004 | 08:57 PM
brown 4x4's Avatar
brown 4x4
The vacuum line to the MAP sensor is a black hard plastic line. The white line you describe goes to the fresh/recirculate air door vacuum motor. It's supplied with vacuum when the a/c switch is in "max a/c" and "off".
Old Jun 13, 2004 | 09:11 PM
miked79928's Avatar
miked79928
I thought it had something to do with the a/c.
