rear main
Old Jun 13, 2004 | 05:20 PM
stang88's Avatar
stang88
rear main
hi, i have an 89 f350 with a 351w it recently out of nowhere just started leaking oil out the rear main about a quart a week i put in it, i was wondering if anyone has ever done this project? if you have or if you know how any help would be greatly appreciated thanks
Nate
Old Jun 17, 2004 | 07:37 PM
youngjedi82's Avatar
youngjedi82
Fairly involved job them rear mains are to replace. Just done mine on my 87 302 AOD 4X4 Bronco. Had to drain oil, remove skid plate if equipped, remove front driveshaft, move tranny/tranfer case back, take fly wheel off, and then replace seal along with oil pan gasket if needed, also seal could be either a 1- or 2-piece. Mine was a 1-piece. Be easier if it's a 2 wheel drive cause then it's just moving the tranny back.
