Rear diff and trans codes
Old Jun 13, 2004 | 12:02 AM
rgillies1986's Avatar
rgillies1986
I have a 1986 F150 302 4X4 automatic w/ overdrive. The driver side door codes are all removed, so I am unsure what rear end and trans I have.
I pulled the codes off the rear end and trans, any help is greatly appreciated.
Trans code:
RF-E39P-7006
Rear end code:
5910P
55 88 6C03
Also, would the rear end be limited slip? I am assuming that it is not because when the rear tires are off the ground and I turn one tire, the other one turns in the opposite direction.
Thanks
Old Jun 13, 2004 | 12:48 AM
fai4g63's Avatar
fai4g63
You have a AOD transmission and you are missing some numbers for the rear. But it looks like you have a 8.8 rear with 3.55 gears.
mcali2
Aug 9, 2014 11:38 AM
a77bronc
Jan 6, 2010 10:04 PM
TonyJestis
36
Apr 14, 2009 03:44 AM
35Rem
Apr 17, 2006 06:16 AM
