Sponsored by: Auxito
Engine Wash
Old Jun 12, 2004 | 09:49 PM
mountainman's Avatar
mountainman
Talking Engine Wash
i want to wash my engine. car wash has engine wash detergent, slow yellow soapy stuff,, how do u do it.. spray stuff on, let soak,, spray off but not too hard? want under my hood to look as good as the outside. tx
Old Jun 12, 2004 | 10:03 PM
KenB's Avatar
KenB
Wouldn't use car wash for engine. Engine and parts in area needs to be cold for one thing. And- That's just too much water around electronics.
Unless you mean taking an engine about to be rebuilt, and take it in the bed of a truck/trailer.
Consider using something like 'Engine-Brite', (spray cleaner) available all over the place, follow instructions on can, you'll probably need several cans.
It's not the most powerful cleaner compared to something like carb cleaner, but much less likely to do damage with it.
Old Jun 13, 2004 | 12:00 AM
mountainman
thank u, but it sprays on soft, and then u rinse it off slowly, what do u think of that?
Old Jun 13, 2004 | 12:21 AM
DeckedoutF150's Avatar
DeckedoutF150
i have sprayed mine off at the car wash many times and no problems at all. but am even better way is to have it steam cleaned, especially if it has a distributer
Old Jun 13, 2004 | 12:40 AM
mountainman
thank u, steam cleaner, hmm, i always thought u could soft degrease the engine, then spary it off, not being crazy spray.
Old Jun 13, 2004 | 02:36 AM
mrwhitefolx's Avatar
mrwhitefolx
best stuff i ever used for cleaning engines is just plain spray on oven cleaner just spray it on your engine and drive around until the engine gets good and hot then rinse it off
Old Jun 13, 2004 | 12:25 PM
DeckedoutF150
if you have access to an air compressor and you spray your motor off at home you might want to blow it off with the compressed air.
Old Jun 13, 2004 | 02:07 PM
AegisSailor's Avatar
AegisSailor
I wouldn't even consider spraying water into the engine compartment on purpose. That's just asking for trouble. It's an engine, it's supposed to be dirty.
But since I'm guessing your going to do it no matter what is advised in this thread, then at least use your garden hose at home vice the pressure washer. And be sure the engine is cold. Cover the plugs and coil(s) and be sure not to soak the air filter. Make sure the caps to all the fluids are on tight so you don't get water somewhere it's not supposed to be.
Good luck.
