EGR Plate connection ?
I picked the truck up from a guy that ripped most of the emissions equipment out-but leaving many of the hoses hoked up to thier original ports, but just hanging in a big clump off many of the various switches, etc that were originally part of the AIR system. FWIW the intake is an Edelbrock Performer, as well as the carb.
I am in the process of removing or properly routing the hoses when I came to the fitting on the front of the EGR plate, directly under the PVC fitting on the carb. It has a hose leading to "never never land"
Where should this hose be routed? Or, can the port be capped?
Thanks in advance for your suggestions
As far as your question: Since all of my emmissions crap is still intacted I may be able to help. What kind of carb? The vacuum for the PVC on the Holley is on the passenger side, the 4350 is directly in the rear (where the EGR is located).
