clogged c. convertor
Old Jun 12, 2004 | 01:15 PM
nomadic's Avatar
nomadic
Talking clogged c. convertor
If the cataytic convertor...(however it is spelled) is clogged, and needs to be replaced...how will it make an engine react....? Thanks ..Nomadic
Old Jun 12, 2004 | 03:37 PM
lastchance's Avatar
lastchance
It will make your engine feel really powerless!! It will rev slow, gas mileage will be bad..seems to me there was a test you can do with a vacuum gauge to determine if you have an exhaust restriction...maybe someone else will know, otherwise I'll dig out my vacuum gauge and look.
Old Jun 12, 2004 | 08:32 PM
Faithful Old Road Dog's Avatar
You have a cat on your Ford? What year and state?
Old Jun 13, 2004 | 08:32 AM
1972 custom's Avatar
1972 custom
you can have some one rev it up and feel the flow out of the pipes....and if is bad you will blow a motor...i work on custom exhaust and if if is bad you need a hight flow one....and by the way where do you live that you have to run one on old truck like that ..(clai) is the only place i know where you would have to run one on an pre 74 truck.
Old Jun 13, 2004 | 04:47 PM
rebocardo's Avatar
rebocardo
besides what everyone else posted, many times a bad cat will actually turn a dull red and the floor of the cab will get very hot.
