Sponsored by: Auxito
Tire wheel combo
Old Jun 12, 2004 | 12:09 PM
Pullit's Avatar
Pullit
Question Tire wheel combo
2001 F150 will 15, or 16 inch wheels fit what is the largest tire that will fit un-lifted
Old Jun 12, 2004 | 05:06 PM
Rambo's Avatar
Rambo
Check the sticky at the top of the page, it gives detailed answers for both 2wd and 4wd.
Old Jun 12, 2004 | 05:44 PM
5.4AZ4X4's Avatar
5.4AZ4X4
For a 4X4 you can go as big as a 285-75R16.
If you want to go the next step you technically can squeeze a 315-70-R16 (35in) without a lift kit installed. You will have to crank the torsion bars up a little and trim a little plastic but it has been done, many times. If you turn up the bars any more then 3 turns I would recomend getting it alligned afterwards. Thats my opinon.
