Fog light relay?
Old Jun 12, 2004 | 10:28 AM
2thdoc's Avatar
2thdoc
Fog light relay?
I recently bought a used 2001 F350. Can't get the fog lights to work. New bulbs, fuses are ok, pulled switch out of dash and it appears to be alright. Is there a relay for the fogs? If so, where is it located? Other than a broken wire, only other things I can think of that might be causing the problem is a bad ground or possibly the multi-function switch on the steering column. Any suggestions would be appreciated.
Old Jun 12, 2004 | 08:09 PM
Franklin2's Avatar
Franklin2
I am sure there is a relay. But I don't know where it is. Do you have a bank of relays under a cover in the engine compartment for the fuel pump, computer, etc? Maybe it's in there.
