whats the right gap?
Old Jun 11, 2004 | 04:04 PM
bills11's Avatar
bills11
I went to the parts store for some new plugs and the guy told me .44 gap was the only gap he had listed for my truck. I'm using autolite 45 plugs. My manual says .34 to.36 I'm not sure which one is the correct gap.I have pionts so i'm thinking the larger gap, .44 would be for electronic igniction. Is this right? my truck is a 74 f100 360. any info would help Thanks.
Old Jun 11, 2004 | 04:16 PM
2ndmouse's Avatar
2ndmouse
I gapped mine at .035, as I understand it if you have a really hot coil setup you can run a bigger gap, but a smaller stock coil should be gapped conservitivly at .035 to insure a good hot spark.
I have stock stock stock aI dunno what the ratings are so i just erred on the side of caution, it runs pretty well now. I have points, i dunno if elecronic ignitions are stronger and need a bigger gap...
my feeble 2 cents..
Old Jun 11, 2004 | 04:34 PM
bills11's Avatar
bills11
thanks for the info, they were at about .35 when I bought the truck so that sounds right
Old Jun 11, 2004 | 05:09 PM
Ratsmoker's Avatar
Ratsmoker
.035 is good for stock coils and points. With an aftermarket coil and pertronix or duraspark I would go with .045 - .050
Old Jun 11, 2004 | 06:52 PM
rvzavala's Avatar
rvzavala
I run .044 + with msd coil and duraspark. You should run .035. If you put a hot coil msd says to run not more than+/- .008 more it create too much duty on the other componets ( rotor,cap and wires). Boosted engines should run smaller gaps and high ignition voltage.
Old Jun 11, 2004 | 07:12 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Ok..MSD has some hot coils...
Your saying no more than +.008 on plug gap? How many volts are the MSD coils putting out? (to lazy to look it up)
And DUI recomends what 50 to 55? at 50K + volts?? I am confused..(wont be the Last) Russ
Old Jun 11, 2004 | 07:19 PM
Ratsmoker's Avatar
Ratsmoker
If you have cheap plug wires and a large gap they will not last too long.
Old Jun 11, 2004 | 07:22 PM
rvzavala's Avatar
rvzavala
I meant to say +/- .008 on the .044, which means on the low side it would be gapped at .036 and on the high side would be .052. On a .035 gap +/- .008 would be .027 and on the high side would be .043 gap. Sorry about that, I still experimenting with my set up and I may opening them up a little bit more from about .046. Wish me luck.
Old Jun 11, 2004 | 07:26 PM
rvzavala's Avatar
rvzavala
Too much of a gap will burn you other componets up faster, and to small of a gap could cause preignition. So be safe and stay with .035. And I will stay below .050. Good luck
Old Jun 11, 2004 | 07:32 PM
RapidRuss's Avatar
RapidRuss
OK....I'am glad we got that one taken care of? LOL!! IM tired..
Ya Sean..If ya run crap..ya get what ya pay for!!
I have seen guys when I was hot and heavy into it..buy ..back then,,$600 worth of ignition parts..and run resister plugs and wires, cause they didnt want noise on the car radio's...LMAO!!
I guess thats why I always had a tape deck!! LOL
EFranzen
Jan 20, 2017 10:51 AM
Stretchmobile
Nov 22, 2016 05:31 PM
PeanutHWD
Feb 21, 2016 09:32 PM
Jrock909
Nov 22, 2004 02:53 PM
dbuck50
Oct 2, 2003 11:22 AM
