Gcwr?
Old Jun 11, 2004 | 02:21 PM
Thorndragon's Avatar
Thorndragon
Red face Gcwr?
what is GCWR? none of the stickers on the truck show me ? how can i calculate mine? my GVWR is 5550 lbs...front is 2650lbs ...rear is 3200 lbs...axle is H9 whatever that means...lol...bumper says 5000 lb limit w/500 tounge weight...installed reese hitch says 6000 lb w/ 600 lb tounge weight...?????...HELP...I have a 98 f-150 regular cab short bed
Old Jun 11, 2004 | 04:13 PM
NoMo's Avatar
NoMo
Gross Combined Weight Rating
GCWR is the maximum amount of weight allowed for truck and trailer together.
The GCWR should be listed in your owner's manual.
Old Jun 11, 2004 | 10:21 PM
rclarke's Avatar
rclarke
From 1998 Ford towing guide:
F150 gcwr= 10,000lbs with 4.2l and 3.55 rear end
11,500lbs with 4.6l and 3.55 rear end
12,700lbs with 5.4l and 3.55 rear end and 16 inch wheels
12,200lbs with 5.4l and 3.55 rear end and 17 inch wheels
Towing capacity varies from 5800lbs to 8200lbs depending on engine and other equipment
Old Jun 12, 2004 | 10:37 AM
les Paul's Avatar
les Paul
Thumbs up GCWR 2004 New Body style Ford F-150
I have been doing some reading on this subject and the towing guide that came with my new 2004 ( new body style ) Supercab 4x4 (145" wheelbase)
5.4L engine. 17" tires and 3.55 rear axle states as follows Maximum GCWR
is 14,000 lbs and the maximum trailer weight is 8300 lbs. It states not only does engins size make the difference but tire size and wheelbase also adds to you GCWR . The bottom line is the GCWR differs with each make depending
on Engine size, Axle ratio, wheelbase, tires, etc etc. I know it's not specific
to your model but thought it may help
hope this helps
les paul good luck
whiteboyslo
Jun 28, 2012 09:34 PM
bheaver
Jul 30, 2010 05:36 PM
TractorM3
Apr 1, 2009 06:20 AM
Rwing21
2004 - 2008 F150
Apr 7, 2008 09:54 PM
