Plugs
Old Jan 7, 2003 | 07:33 PM
CobraXP's Avatar
CobraXP
Plugs
Old Jan 13, 2003 | 01:40 PM
tonga3's Avatar
tonga3
Plugs
Can anyone recommend a good plug for 99 5.0 explorer, and if possible tell me the proper gap.
Thanks in advance.
Old Jan 13, 2003 | 10:31 PM
e_no_g's Avatar
e_no_g
Plugs
If you buy platinum plugs, they dont require gapping. I have Bosch Platinum II's on mine. If you just get the regular plugs, look on the label under the hood, where it says the type of oil to put in. At the bottom it will tell you the gapping specs.
Old Jan 14, 2003 | 09:30 PM
SplashMan's Avatar
SplashMan
Plugs
I run just regular Bosh platinums. Work great and are not that pricey.
Old Jan 16, 2003 | 07:42 AM
CobraXP's Avatar
CobraXP
Plugs
I stick with the Autolite Platinums. Have not had any problems out of them yet. I bought a set of NGK Platinums one day when I was buying plugs for my jet ski's. Figured I would give them a try, but have not put them in yet to see how hey do...
I would recommend always checking the gap on all plugs you put in. Boxes can be dropped, it, etc, and can messs up preset gapping. Autolite and the Bosch come pregapped, but I have found some that have been wrong and needed to be regapped...
Old Jan 17, 2003 | 02:17 AM
hrbib21's Avatar
hrbib21
Plugs
Motorcraft.
Old Jan 19, 2003 | 11:47 AM
marrug's Avatar
marrug
Plugs
Bosch Plats are ok. changed mine up at around 25,000 from factory, couldt tell the difference, to tell the truth, from OE...by all means check gap anyway, and use proper lube when screwing em in...
Old Jan 20, 2003 | 06:26 PM
tonga3's Avatar
tonga3
Plugs
Thanks for the info everyone, went with bosch plat 2's. What a big pain to install.
