windage tray
Old Jun 11, 2004 | 12:49 AM
bigblocksix's Avatar
bigblocksix
windage tray
is a windage tray worth it on a truck motor thats never gonna see more than 5000rpm, will it free up any power? some guys say i ads about 20 horse, some say its a wast of time. opinions?
Old Jun 11, 2004 | 09:40 AM
beartracks's Avatar
beartracks
I believe generally it's help mostly at higher rpm's. However I saw a test in one of the magazines that shown across the board encrease of something like 8hp. I think I would use one next time on a performance 400 or 460 build even for 5,000rpm. There is a ton of metal going round and round down there to aerate and keep the oil suspended.
Old Jun 11, 2004 | 11:48 AM
ga302p's Avatar
ga302p
I personally dont think you will see any noticeable increase in hp below 5000. I only use them in engines that are going to spin above 7500. For a true race engine, dry sump is much better.
Old Jun 11, 2004 | 05:20 PM
Ratsmoker's Avatar
Ratsmoker
15HP at 6500 rpm is the general concensus. I use one but have never run without one so I can't tell you from experience but I do rev to 6,000 regularly. One fact is that it will not hurt anything. It keeps oil from splashing up on the crank so it will give you a little bit.
Old Jul 7, 2004 | 10:46 PM
FEmtnmax's Avatar
FEmtnmax
Grumpy Jenkins book says the windage tray is good for all rpms, but he highly recommends cutting most of the metal sheeting out and riveting in wire mesh so the oil thrown off the crank does not bounce off the metal windage tray. I have not tried it, but it makes sense.
