Engine/Electrical problems
Old Jun 10, 2004 | 11:54 PM
Broken Ford's Avatar
Broken Ford
Exclamation Engine/Electrical problems
I have a 1993 F-150 351 5.8L V8 EFI and i am having problems. When ever I start driving, and it starts to warm up the engine starts to miss out. Causing jerking. I went through and replace the plugs, wires, rotor, and distrubutor cap, but the problem is still there. What could the problem be???
Old Jun 11, 2004 | 11:42 AM
RTM's Avatar
RTM
Since no one mentioned it yet I guess I will ask. Have you checked for codes yet?
Old Jun 11, 2004 | 11:47 AM
Broken Ford
that i have not done. I have gotten some advice to it being the ignition control module so i am set out to change that.
Old Jun 17, 2004 | 11:35 PM
BroncoBill's Avatar
BroncoBill
Thumbs up Engine trouble
I've had the same trouble with my '82 Bronco. As you, I was smart enough to research the problem before I spent mmore money on another carb rebuild. I saved hundreds of dollars when I found out the problem was the ignition control module, a $20 part.
