I may be able to get a Bronco of the same year with a bad engine. The only issue is that this Bronco has an auto tranny whereas mine has the T18 4-speed.
So will the transfer case from an auto tranny match my T18 too?
as long as the auto has the same tcase it will bolt right up. Meaning if the auto has a 203 and you have a 203, if the auto has a 205 and you have a 205 they are a easy swap. Now if you have a 203 and the other has a 205 they will swap right over except your drive shafts will nto be the right lengths. Which brings up another point. 78 broncos use 1310 series u joints and the 79's use 1330 series, they are not swapable between the 2.
When I twin sticked my 205 I bought a complete seal kit is it like $30 from any drivetrain shop.
