Sponsored by: Real Truck
tire pressure ?
Old Jun 10, 2004 | 10:10 AM
brianas's Avatar
brianas
tire pressure ?
I put michelin ltx 285\75-16 load D tires on a while back
they say 65lb. on the tire
but the tires really bow out and when I load weight in the back the tires really bow out alot
I know a load D tire was not a good idea--but you cant get a 285\75 tire in load E
but I already got the tires and there on --can I put more air pressure in these? will this help
btw-I emailed michelin and they just replied that the spec sheet says 65lbs pressure for maximum weight load
thanks
Josh Brianas
Old Jun 10, 2004 | 10:19 AM
wlihntr's Avatar
wlihntr
i have 285/75-16 bfg at's and they are load range D as well, max pressure is also 65psi, when i put my camper on my truck(2500#) the tires do bow out a bit. as far as comparing the 265/75-16 E-range to the 285/75-16 D-range. they both have about the same max load (within 100#)
Old Jun 10, 2004 | 10:22 AM
Fredvon4's Avatar
Fredvon4
Josh if you put a load on and over inflate the tires you are in for big trouble when they blow out at speed. Load rang D is OK for no load cruising and up to the max weight and PSI rating but, if you are gonna use the truck for hauling any serious weight you need the right tires...
This assumed you have a SuperDuty Ford.
I had a front side wall failure (not due to inflation, tire defect) at 75mph, empty, and the truck was a real bear to keep straight and get over to the side. Hate to even think about it with a load on!
Old Jun 10, 2004 | 10:50 AM
brianas's Avatar
brianas
OK thanks for the input-Ill leave it at 65lbs.
it is a superduty - I put between 4-5 k lbs. in it each morning
I saw that the max weight load on these 285 tires were about 3300 lbs.
which was identical to that of the load E tires--so I figured all would be well when I got them---but- I guess there is a big difference in the side wall consturction and that makes the difference
thanks
Josh Brianas
Old Jun 10, 2004 | 11:01 AM
Loyd Lucas's Avatar
Loyd Lucas
If the Michelin tires you had installed are LTX M/S LT285/75/R16D's they are load range "D" tires rated at 3305 pounds at 65 PSI. You shouldn't have any problems.
Old Jun 10, 2004 | 12:12 PM
NoMo's Avatar
NoMo
HELLO Fredvon4! Glad to see you're back with us!!
Josh-
What size rims are you running? If it's the OEM 16x7s, they will really amplify the "bulge". Most 285 series tires are supposed to be on 8" rims. Now, for loading 4-5k lbs in the back of your truck, you are WAY overloaded! Be careful!
Old Jun 10, 2004 | 12:29 PM
Fredvon4's Avatar
Fredvon4
NoMo
Back cuz I am hunting for all the info I can absorb on the 05 V10 F350s.
May 1 I managed to bury the front end of the platinum into a east texas pine tree and assinate the best truck I ever owned!
No injury, seatbelt and airbag worked as advertised and made me a believer!
If I can figure out how I will post pics some day.
Old Jun 10, 2004 | 12:39 PM
daimon1054's Avatar
daimon1054
Michelin always look low on air. I am for ever checking my wifes truck, every time I see them I think they are low but the PSI is right.
Old Jun 11, 2004 | 05:43 PM
brianas's Avatar
brianas
yes the tires are on stock rims-16x7
the tire dealer said it would be fine-they put that size on lots on SD's
I had to have the springs beefed in the truck to carry that much weight
but Ive always done it with out trouble--and its for work
its just with the weight in the truck the side walls really seem to give out
while driving highway\cornering etc....
I guess Im just getting a good education on tires now
I hope this thread will help advise some one else in a similar situation
about tires
btw--Im ordering a new truck this year--and Ill keep load E tires on her
Josh Brianas
