whistling noise-PLEASE HELP
Old Jun 10, 2004 | 12:31 AM
82f1504x4's Avatar
82f1504x4
i have an 82 f150 4x4 with a 4.9l straight 6 two weeks ago i was driving home over blewett pass and my rear main seal completely went out and it took me about 2 gals of oil to make it home it never ran out tho i pulled over several times, i got it home and tore the whole thing a part to reseal everything i got it all back together and am trying to get it running right i have the timing set and its running strong but there is a very loud high pitched whistling noise coming for the side of the intake and exhaust, i thought it was the manifold leaking retourqued everything it was all fine i made sure everything is right torque now its been about 3 days and i still cannot figure it out any suggestions would be helpful this my daily driver and i need it desperatly please help
thanks in advance
justin
Old Jun 10, 2004 | 07:17 AM
srercrcr's Avatar
srercrcr
Try spraying some WD40 around there while idling to see if the noise stops.
Do it before the engine gets real hot....could be flamable.
Old Jun 10, 2004 | 08:41 AM
5_labsownus's Avatar
5_labsownus
It sounds like a vacuum leak and could be the intake, carb base, EGR adapter or a vacuum line/port cap.
Old Jun 11, 2004 | 01:23 AM
82f1504x4's Avatar
82f1504x4
figured it out it was the egr, i sprayed with wd40 and never did anything different so i just had a hunch and pulled it off and started it and the noise was gone but it does run like crap now i gotta go pay 47 bucks for a new one thanks for the help
