rack and pinion???
Old Jun 9, 2004 | 10:51 PM
fe8u's Avatar
fe8u
rack and pinion???
can i be done easily on a 76 f150 2wd. keep the stock suspension, just change the steering setup. I plan on keeping my truck for awhile, would like to try something different. any thoughts on this.
Old Jun 9, 2004 | 11:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
It would mess up the steering geometry even worse than it is.
Many rack and pinion units are too light duty to run on a truck.
Old Jun 10, 2004 | 04:11 PM
samwe's Avatar
samwe
It would be difficult to do on a 2wd because of the geometry.
To elaborate, you want you steering linkages to swing in the same arc as the suspension links. That is would be hard to do with a rack and TIB.
I think on a 4wd it would work good if you could get a strong rack.
