Sponsored by: Kumho
ABS problem
Old Jun 9, 2004 | 10:03 PM
03 SuperDuty FX4's Avatar
03 SuperDuty FX4
ABS problem
My 95 F-350 dually has a ABS problem. I have cleaned the rear end sensor twice and have replaced it once. I have replaced the ring that’s in the rear end that the sensor reads. I have also adjusted the rear drum brakes and checked the fronts and both look fine. I still have the abs light at times and almost every time I stop the pedal pulsates. The pedal pulsates whether I’m pulling a trailer or not. Any help will be greatly appreciated.
Old Jun 10, 2004 | 08:54 AM
MrCBofBCinTX's Avatar
MrCBofBCinTX
check the wires from the sensor to whereever they go. since abs comes on when the ring stops, a lack of signal due to a broken wire sounds reasonable to me. could be real hard to find the exact spot though if i'm right
Old Jun 10, 2004 | 08:55 AM
MrCBofBCinTX
or could be the connection at the other end, not the sensor
