Problem With Power Lock.
Old Jun 9, 2004 | 09:35 PM
MemOrex's Avatar
MemOrex
Exclamation Problem With Power Lock.
My problem is that whenever I lock my doors with the powerlock I cant open the drivers side door with the key. I can open the passenger's fine. But, if I manually push down on the locks, the drivers door does open w/the key? Any suggestions?
Old Jun 10, 2004 | 12:06 AM
DPS3749's Avatar
DPS3749
I have that problem on a Ford van, and my son's '85 Mustang. The power door lock motor's mechanism is bad; button is real hard to operate by hand. At first I tried lubing the door lock linkage, but that didn't help. The motor is strong enough to operate the linkage, but not with the key. I thought about drilling a small hole in case, and squirt some oil in there to lubricate to maybe loosen up. Got nothing to lose; have to buy new one anyhow (around $50 ).
Old Jul 15, 2004 | 02:06 PM
MemOrex's Avatar
MemOrex
Long time since this topic....But i since i had to take off door panel today, i was looking in the lock stuff and saw that when using the power lock button it sorta "overlocks" it... I can open it with the key, but have to use extreme force. Tried some WD-40 but that didnt work.
Old Jul 15, 2004 | 08:34 PM
DPS3749's Avatar
DPS3749
I recently pulled out my door lock motor, and it seems to hang up in spots when I operate it manually. If you move the actuator rod around it starts working quite freely. I worked some grease into the innards, but didn't help. I left it off and put everything back together for now. Operates really good now with a key. I'll have to replace the motor when I get some extra cash.
Old Jul 16, 2004 | 12:59 PM
Pony Power's Avatar
Pony Power
Same problem with my driver side door. What worked for a year or so for me was to unscrew the plastic lock **** and let oil run down the rod, enough seemed to make it to the linkage to free it up for awhile. The oil doesn't do it anymore so I just don't use the power lock button.
