Air/fuel hook up
Old Jun 9, 2004 | 08:18 PM
Benny R's Avatar
Benny R
Question Air/fuel hook up
MY 2002 f-250 5.4 has 4 wires on the o2 sensor, which wire and how do i hook the gauge to it. Also is there a spot in the fuse block to hook up the ignition wire so the gauge is on when the key on. Thanks for help
Old Jun 9, 2004 | 09:17 PM
5_labsownus's Avatar
5_labsownus
Most sensor wires are gray. You should find an open slot in the block or buy a tap lug from NAPA that slips under the fuse.
