[B]Wipers[/B]
Old Jun 9, 2004 | 07:32 PM
Bogus's Avatar
Bogus
Question [B]Wipers[/B]
The wipers on my 89 Ranger only run on high and they do not return to the bottom of the window when they are off. They just stop wherever they are at.
Anyone esle seen this?
Old Jun 9, 2004 | 07:51 PM
Vin 95's Avatar
Vin 95
I've seen SEVERAL posts on this,its a common problem.my wipers just turn on by there self at random,but it does'nt happen enough for me to replace the switch yet.Do a search for WIPERS and I bet you find some info.
Old Jun 9, 2004 | 09:20 PM
Bogus's Avatar
Bogus
They don't turn themselves on.
I did a search and I found one other person with my exact problem but no solution was presented.
Old Jun 9, 2004 | 10:03 PM
hreed's Avatar
hreed
Sounds like a bad relay in the system. I'm not sure on your 89, but there should be a power distribution box under the hood, probably on the drivers side close to the master cylinder. Check to see if there is a relay for the wipers there.
Old Jun 10, 2004 | 08:19 PM
Ken00's Avatar
Ken00
Sounds like a bad governor to me.
