Changing Transfer Case Fluid
Old Jun 9, 2004 | 11:24 AM
tmorris1's Avatar
tmorris1
What is the easiest way to add fluid back into my 97 F150 transfer case? Use a Suction Gun or do they make a small pump to pump from the bottles? I was going to change to Mobil 1 ATF.
Old Jun 9, 2004 | 11:54 AM
FordPerf300's Avatar
FordPerf300
I use a sta-lube pump that is designed for the gallon sized gear lube jug, works fine just cant screw the pump down on to the bottle like you can on the jug
Old Jun 9, 2004 | 01:42 PM
KJKozak2's Avatar
KJKozak2
I have a hand pump I bought for changing the lower unit lube in my outboard. Works OK, but it's slow.
A long time ago, I made a filling device using a few pieces of rubber hose and a small 12v air compressor. I drilled a 3/8" hole in the cap of the lube bottle and ran a hose from the bottle to the t-case. Then drilled a small hole and inserted a valve stem or piece of metal fuel line. Pumped air into the bottle and it forced the lube out the other hose.
Just a thought.
Kevin K.
Old Jun 9, 2004 | 02:38 PM
tmorris1's Avatar
tmorris1
Thanks for the replies
