Offroad & 4x4
Which leveling kit?
Old Jun 9, 2004 | 06:21 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
Which leveling kit?
I have a 93 F-250 that I plan to use for mild off road use. The problem is that it has that stock appearance where the rear is aprox. 2" higher than the front. I've been searching around for leveling kits and it seems that each company has their own method of taking care of this. Tuff Country has an add-a-leaf, TrailMaster and Superlift have some sort of extended spring brackets. Which one is better???? I'd like to level off the front end, but don't want to run into a huge hassle with alignment, pitman arm probs, sway bar probs, shocks, brake lines, blah blah blah...any suggestions?
Old Jun 9, 2004 | 09:59 AM
fishmanndotcom's Avatar
fishmanndotcom
just take out the rear blocks! they should be 2"er's but if they are the 3" blocks get a 1" spacer anhd slide in there. although if it were me i would leave it!
-cutts-
