what to do with a 360?
Old Jun 8, 2004 | 09:32 PM
77f2504by4's Avatar
77f2504by4
Arrow what to do with a 360?
im thinking about buyin this 360 thats in my local junky just for a rebuild. but i wanna know what kind of cubes are possible from a 360. can i turn it into a 428 or 427? if so i'd buy that motor in a second. i hear that the motors cant be over bored that much, is sleeving an option? basically im looking to make massive amounts of power and tourqe with huge amounts of cubes. im currently in the middle of my 400 project, but these fe's are getting hard to find, so i dont wanna miss out on this one.
Old Jun 8, 2004 | 09:37 PM
fordeverpower's Avatar
fordeverpower
I don't know but it you might be able to put the 428 crank in a 360 or get an aftermarket crank. I wouldn't want it bored any more than .060. YOu should get just enough to clean up the walls.
Old Jun 8, 2004 | 09:41 PM
fordeverpower
A 360 with a 428 stroke and .030 overbore is 416ci and .060 is 420ci.
Old Jun 8, 2004 | 09:47 PM
77f2504by4's Avatar
77f2504by4
hmmm, i like those numbers. i love 400+ ci motors. i think that 416 would be a nice number of cubes. the thing i love about fe motors are those powerbyford valve covers . what should i look for in a junk yard motor? im going to rebuild it, so i dont think its neccecary to be running, but im not sure. and how much, is a 360 worth? 500 bucks? less?
Old Jun 8, 2004 | 09:59 PM
fordeverpower
200 or 300 maybe 500 if it runs. I would try to find one under 150,000 miles. Look for a 4bbl unless you plan on buying an edelbrock intake.
Old Jun 8, 2004 | 10:04 PM
77f2504by4's Avatar
77f2504by4
i do plan on buying an edelbrock intake, as aluminum is lighter than cast iron. and these mostors allready weigh enough. why under 150k? i was under the assumption that as long as a total rebuild was in mind milage doesnt matter. i do plan on going with new pistons and such as well.
Old Jun 8, 2004 | 10:06 PM
rusty70f100's Avatar
rusty70f100
I got one for $35 at my local junkyard. They're a dime a dozen.
If you really like cubes you could get a SCAT 4.25" stroker crank and have 445 cubes with a .030" overbore.
I'd suggest finding one still in a pickup truck, preferably with D2TE-AA or newer heads, since they'll have hardened unleaded friendly exhaust valve seats.
360's and 390's share the same block and heads, the only difference is the crank, rods, and in some cases pistons. They're ok with overbores up to about .060", after that you'll want to have 'em checked for wall thickness. .080" is about the max I'd take one.
Old Jun 8, 2004 | 10:11 PM
77f2504by4's Avatar
77f2504by4
what years did those heads come in? its very hard to find casting numbers under grease grime and rust. LOL 445 i like the sound of that!!
Old Jun 8, 2004 | 10:13 PM
Randyb12's Avatar
Randyb12
I got a 390 shortblock from my local junkyard for 150.00. If you are going to buy heads and intake from an aftermarket source why pay extra for a longblock. The only parts that are left over from the 390 shortblock are the crank, rods and of course the block. Everything else is new. Oh yeah, the timing cover and damper were reused also.
Old Jun 8, 2004 | 10:15 PM
rusty70f100
Those heads came 1972 and later. Actually, with a rag and a flashlight, it's not that hard to find the head casting number. It's right between the two middle spark plugs, on a flat spot looking right up at you.
Old Jun 8, 2004 | 10:18 PM
77f2504by4's Avatar
77f2504by4
so for the sake of example, if i saw a 75 f350 that has an fe, its probably either a 360 or 390 with those heads?
Old Jun 8, 2004 | 10:29 PM
fordeverpower
I guarantee it!
I myself would want a motor is less then 150,000 miles would beless cylinder wall wear, lifter bore wear, and less chance for cracks and other fatigues in a engine. But for the most part it doesn't matterhow many miles it has. I (me, myself) would want under 150,000 but it doesn't mean you have to.
Old Jun 8, 2004 | 11:09 PM
77f2504by4's Avatar
77f2504by4
Originally Posted by fordeverpower
I guarantee it!
well that makes sence. i never thought of it that way. now all i need to find is a motor to work on. im sure a local junky has a couple of them. as ive seen one recently. as to how much they want, probably top dollar just because i want it. hopefully i can get the motor mount towers with it. unless i can change the towers from a 351m. but i doubt it.
Old Jun 9, 2004 | 01:29 AM
fordeverpower
i am curious as what you think about the 351m and 400 motors. I try to ask everyone what they think.
Old Jun 9, 2004 | 11:07 AM
rusty70f100
I know a guy up at the college that has a 400 in his car, it's a Torino I think, and it's original. It runs good. He thinks a lot of it.
I dont know, if you could put 351C heads on a 400, you'd have quite the runner.
