Learned something new today
So my tires are LT265/75R16 (think that's right) BFG.
The 265 (per a tire man I spoke to today) indicates millimeters.
But the 16 indicates inches.
Isn't that mixing apples and oranges?
So what does the 75 mean?
Anyone know a site where I can LEARN tire stuff?
70% of the 265mm is the sidewall height of the tire.
16" rim is what the tire will mount to.
I hate mixing metric and english too. In fact, I hate the english system all together.
Pete
Pete
265= section width in millimeters
75= aspect ratio/section height (between ground and bottom of rim
16= rimdiameter in inches.
If you want to covert this and find out what the measuments are here is the formula
265mm divide by 25.4 = 10.4 inches wide then take that number and multiply by the aspect ratio 10.4 x .75 = 7.8. Hope this helps, I found the conversion numbers at tiresafety.com
Said tire is 265 mm wide, each sidewall is 75% of 265, or 198.75mm. Converting that to inches makes it 7.825 inches. Double it ('cause there is a sidewall on both sides of your tire) makes it 15.65 inches....add the 16-inch rim to get 31.65. Your tire is 31.65 inches tall. Now, with all that said....different tire makes make tires differently, just like you can buy clothes the same size from different makers and they won't be EXACTLY the same size. Same holds true for tires. These calculations will get you pretty close, though.
NOW...if you start talking about those 33's, that is different. The 265s are RADIAL tires, while the 33s are not. They are sized differently. A 33-12.50 is 33 inches tall and 12.5 inches wide. That's a whole different deal.........
