Dist. Eldebrock Vac hook up
Old Jun 8, 2004 | 01:10 PM
breeder@grenergy's Avatar
breeder@grenergy
What vacuum port do I use on my edlbrock carb from 79 351m distributor.
Old Jun 8, 2004 | 01:54 PM
beartracks's Avatar
beartracks
The stock ignition set up would use the ported vacuum and aftermarket units usually the full vacuum. Don't know phisically whichi is which.
Old Jun 8, 2004 | 02:21 PM
Ecuri's Avatar
Ecuri
Manifold is on the driver side and ported on the passenger.
Tracks is correct on the way it came but I have been getting a bit better MPG running the manifold on a stock distributor. But beware of detonation esp if you are pulling a trailer. GL
Old Jun 10, 2004 | 09:58 AM
breeder@grenergy
Thanks So Much.
I was able to dial it in and seem to run the best off the manifold.
This was my first time using a internet forum what a neat deal.
