vacuum lines
Old Jun 8, 2004 | 08:10 AM
jeter's Avatar
jeter
vacuum lines
yesterday i found a vacuum line laying to the side. the only vacuum lines that are attached are the brake booster and i think an egr valve. on the driver side fender under the hood is were all the vacuum lines runn too. i was just wondering how mant vacuum lines i was suposed to have. i have a 1993 ford 7.3 liter non-turbo 4x4. i dont know how long this line has been disconnected
Old Jun 8, 2004 | 09:55 AM
ditch witch's Avatar
ditch witch
not sure on a '93, but there is a vacuum line on my '84 which goes to a vacuum motor tucked back near the firewall on the pass. side right under the windshield which operates a heater/AC door. There is a small check valve in the lines there also. It's all pretty simple stuff once you understand where it's going.
Old Jun 8, 2004 | 11:03 AM
Spectramac's Avatar
Spectramac
If you can't find where it goes, at least plug it so it isn't stealing vacuum from your brake booster.
Old Jun 9, 2004 | 05:58 AM
jeter's Avatar
jeter
front brakes
yesterday when i was coming to work my driverside brake would not release. i let it sit for a while and when i drove home it didnt lock up at all. could my brake caliper be sticking . 1993 ford f250 7.3 non-turbo
