Heat causing startup problem in 96 Ford E150
Old Jun 7, 2004 | 08:10 PM
thomas_h's Avatar
thomas_h
My boss drives a Ford E150 (96 or so, V8). I often drive the van into town for lunch, but I am unable to shut it off now that the weather is hot, because the van will not startup again. This happened during a warm spell a month or so ago. Given anywhere from an hour to two hours, the van will start up again. It's about 80 degrees F where I live.
Turning the key results in no clicking sound, other than the normal beeps, but the light indicators and whatnot seem to turn on.
It's a weird problem. The van will start up if you shut it off and immediately turn it on again. Also, if it is cool, you can start/stop it with no problem. The temperature gauge is at about midway when shut off, and once it gets pretty low the car seems to start again. Installing a new starter did not solve the problem.
Any idea what the problem could be?
Thanks for any help.
anon1028
Jan 12, 2015 04:18 PM
Bbasso
25
Apr 26, 2011 01:48 AM
nalts
Sep 18, 2010 07:15 AM
eehoepp
Aerostar
Apr 27, 2007 02:15 PM
