1978 - 1996 Big Bronco
1982 Bronco AC Promblem NEED HELP
Old Jun 7, 2004 | 06:23 PM
tygarcia's Avatar
tygarcia
Exclamation 1982 Bronco AC Promblem NEED HELP
The AC works but only when it is idiling and give a little gas in nuetural. But once you push the gas and it is in drive she stops blowing air. When it is blowing the air is cold but once you take off it dies. NEED HELP LIVE IN SAN ANTONIO AND IT IS HOT
Old Jun 7, 2004 | 08:31 PM
JBronco's Avatar
JBronco
Are you sure that it's not blowing cold out of the defrost and/or floor vents when the air stops coming out of the dash vents? That happens to almost every Bronco, and is a vacuum line problem on the newer ones but I am not sure about an 82.
Old Jun 7, 2004 | 09:14 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Yea I hear ya brother I live in SA too and I am injoying the rain and cool air that we just got in. But now to get too your problem.
You have a vaccum problem, when the engines speeds up it is making no vaccume, this is where your vaccume canistor and bypass valve come into affect.
You have either a bad bypass valve or a rusted or leaking canistor, and/or other cracked vaccume lines, you should go over all the lines while under the hood, also, check too make sure there not clapsed or getting pinched by anything.
Hope this helps.
BTW, what part of town doo you live in?
Old Jun 8, 2004 | 02:22 PM
tygarcia's Avatar
tygarcia
northeast part of town; This may sound stupid but how do you check for a vacuum leak. do you disconnect the canister and you should feel vaccum going to the canister or from the canister??? I have no clue when it comes to vaccum lines!!!!!
Doug351
Texas Chapter
Dec 27, 2013 03:38 AM
Future_LEO
Nov 21, 2011 05:08 AM
Future_LEO
Modular V10 (6.8l)
Sep 19, 2011 09:02 PM
iamstevee
Modular V8 (4.6L, 5.4L)
Dec 24, 2003 11:31 PM
