Sponsored by: Auxito
Throttle Problems
Old Jun 7, 2004 | 02:08 PM
rmartyn's Avatar
rmartyn
Throttle Problems
I'm new and I had a problem with the EGR ports on my 97 4.6L. I found out how to check and clean the EGR ports and did that. One was completly closed off and the other had a very small hole going through. Anyway, I cleaned those out and put everything back together. Went for a test drive and now the code 123 comes up. Something to do with Throttle high imput. Any ideas on what I did wrong or what I need to do to fix it?
Old Jun 7, 2004 | 02:26 PM
rmartyn's Avatar
rmartyn
I found the problem, I had a bad connection with the Throttle Control Sensor..
Old Jun 7, 2004 | 08:33 PM
Racerguy's Avatar
Racerguy
Hi and welcome to FTE
Good to hear that you figured it out.
Old Jun 7, 2004 | 08:47 PM
rmartyn's Avatar
rmartyn
Thanks, I'm sure I'll be back with more questions......
