1978 - 1996 Big Bronco
Fuel Pump Voltage
Old Jun 6, 2004 | 11:37 PM
rustyb's Avatar
rustyb
Question Fuel Pump Voltage
I am still trying to determine if the fuel pump needs to be replaced on my '94 Bronco XLT 5.8L or if I have an electrical problem. The hot wire going to the fuel pump (at the fp plug) has 6.86 volts...is this normal or should it be closer to 12? I have the same reading going to and coming from the inertia switch.
Old Jun 7, 2004 | 05:23 AM
Bob Ayers's Avatar
Bob Ayers
That is way too low, try replacing the fuel pump relay.
