installing intake gasket
Old Jun 6, 2004 | 07:59 PM
fe8u's Avatar
fe8u
I have the victor intake gaskets and wondering if you only put sealer only on the water passages, or on all the ports
428 w/ edel heads and blue thunder intake
thanks Chad
Old Jun 6, 2004 | 08:19 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I think most of the guys just run sealer around the water passes..I know thats how Ratsmoker does his....If ya read down ..he just did this tonight!! Russ
Old Jun 6, 2004 | 08:48 PM
gtex's Avatar
gtex
make that at least 2 of us.
Old Jun 6, 2004 | 09:07 PM
fe8u's Avatar
fe8u
thanks guys
Old Jun 6, 2004 | 09:21 PM
Ratsmoker's Avatar
Ratsmoker
That's all I do. Throw away the end seals and just use a bead of blue RTV instead. RTV won't interfere with the way the manifold meets up to the head and it seals much better.
Don't get crazy with the black RTV. I just use enough to coat it. I also use it between the ports just to hold the gasket in place. I don't let it near the actual intake ports.
