Found a burned down F350
Old Jun 6, 2004 | 06:21 PM
easyryder's Avatar
easyryder
I found a burned down F350 The truck is totaly gutted
I guess my question is 1) Would the rear diff bolt into my truck(4wheel disk) By the way the 350 is a SRW. I can buy the truck less transmision for 300 dollars The front part of the fire got real hot Alternator partialy melted Any input is welcome
Oh the burned rig is a superduty can't tell the year
Mine is a '96 F250 Heavy duty
Old Jun 6, 2004 | 10:21 PM
FoMoCo136's Avatar
FoMoCo136
Need more,,,You really need to know the year of the burned one? Is your truck a duelly? Is your 4X4. If so the gears need to be the same. There could be more.
Old Jun 7, 2004 | 01:22 AM
SoCalDesertRider's Avatar
SoCalDesertRider
A Superduty F350 SRW will have the Ford 10.50" axle. The housing is nearly identical to the 10.25" axle that is in your F250. It should bolt in fine as long as the frame widths are the same between the '97-down and the Superduty (shock and leaf spring mounting positions). I would think the pinion yokes should be the same. Like FoMoCo said, you need the same ratio in both axles.
If the rear disc brakes is all you're after, you may be able to swap the hubs and rotors onto your axle. Don't know how tough the caliper brackets will be to get onto it though.
There is one problem with this though: the wheels.
Superdutys use an 8x~6.8" bolt circle with metric studs and the wheels are hub-centric, meaning they dont center on the lug nuts, they center on the center of the hub. The '97 and earlier trucks use an 8x6.5" bolt circle and are lug-centric and use 9/16" studs. You could end up having to run two different types of wheels unless you want to change the front hubs too...
I don't know that there is all that much braking performance to be gained by switching to the rear discs to justify the hassle of making the switch. I also don't know if you will need the Superduty's master cyl and proportioning valve to go with the rear disc calipers' different fluid volume/pressure requirements.
Burns3006
Feb 2, 2015 10:55 AM
F350Jay
6.7L Power Stroke Diesel
15
Apr 30, 2013 07:08 PM
wescon
Aug 20, 2010 11:37 AM
stingray28
24
Jun 4, 2010 07:55 PM
BEmory
Modular V8 (4.6L, 5.4L)
Sep 14, 2005 09:15 PM
